Some
symptoms of a defective CCD
(Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
