This unit requires separate AC power. If the blue light is not on to begin with - indicating power, no PC will be able to read the USB. There is a hard disc in the unit that needs to spin...it is not solid state like a thumb drive.
Ok. Verify the adapter...do you have another with the same voltage? As a test only. You must test this first. After that you may have to take unit apart or take it in for servicing if still under warrantee. Power must get to the drive. If you had a brownout, it is possible it got fried, or the adapter wire has severed. Internally, the power connect leads may have come loose from the hard disc. Not likely though as I believe they glue them on with hot white glue.
sorry about this....hopefully it is under warrantee.
Yes, I do have a separate AC power. The external was working perfectly until 2 days ago.
I followed your advice and tried other adapters (same voltage), but i got nothing. Better start looking for that warrantee, right? Thanks a lot for your help!
