Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Aug 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Duet Washer Model No. GHW9100LW, Serial No. CSM2608446, Type No. 199-AWM075/GY
Plastic door handle broke at point where it mounts to door. Epoxy repair did not work. Is a handle of stronger material such as metal available?
  • Anonymous Sep 03, 2008
    model GHW9100LW serial csm3002253 whirlpool duet front load , need to know if handle can be orderd
Anonymous
Level 3:
Genius:
  • Master 1,028 Answers
  • Posted on Aug 20, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1028
Questions
Helped
316711
Points
2631
Not unless you make it yourself ..replacement handle is just like the 1 that broke
2answers
What is the capacity of my Whirlpool Duet Washer model number: GHW9200LW?
Whirlpool GHW9200LW Front Load Washer 12 Cycle, 5 Temperature Ultra Plus Capacity ,Energy Star Qualified : Dove Grey on White. Machine Type‎: ‎Standard
Series‎: ‎Gold
Door locked light on but door opens. No other lights lite even when plugged in and breaker switch as been reset. Whirlpool duet front loader ModelGhw9300PW4 serial CST1702832 Type 199 084WT/GY
Allen, We are sorry to hear that your lid lock light is on. If you have tried to reset it from the breaker and the light is still on then we can only recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to [email protected].
Whirlpool duet ghw9100lw lights on, not locked and still won't start
Just above where the washer door strike goes into the latch is a small round piece of plastic that activates a switch in the latch- is that still there? It will push in and come out as it is spring-loaded.
3helpful
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
In the middle of washing get an error that is f/dl or f/du. the door will not open even if you unplug it and plug it back in. You have to wait quite awhile and then try and it will unlock. It does this...
F/dL  and  F/dU error means -------------- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.---------- to resolve ---------
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
2answers
I need to reset duet washing machine to open the door
????? your pump just runs??? is it pumping water???if you rermove the lower aceess panel(3 screws across the bottom) youll gain acess tot eh pump clean out, perhaps its clogged , not pumping any water out
23helpful
4answers
Whirlpool Duet front loading washer - handle broke off
Replacement handles can be found at amazon... click here and take a look Modern Shower Doors at Amazing Prices. I hope this was helpful. Cheers
1helpful
Whirlpool duet
you can remove the lower access panel of unit ( 3 screws across the front bottom of unit), behond there directly in the middle of machine yuoll see large plastic turn screw. that s teh pump housing "filter cleanout". unscreww and clear all debris. be aware however if theres water in machine it will come out on you when you release teh turnscrew
1helpful
2answers
GHW9100LW@ whirlpool Duet grey seal leaks
Here's the instructions you need to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Let me know if you need further assistance. I hope this helps you.
PS I know it's a lengthy read, but it's a simple repair if you follow the directions.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
