SOURCE: Which way do the mower blades mount, on a Craftsman DT4000, 19HP Mower 42" deck?
Hi, make sure to put your blade curve end up. another word facing the motor
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
SOURCE: I replaced my mower deck belt on my Husqvarna
There is a small brace that stops the clutch from spinning and ripping out the wires, i think you may have forgotten to put it back
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: MY husqvarna yth2148 left side deck mandrel and
Did it break or overheat? There is a small spacer washer that goes under the pulley between the pulley and bearing, if that washer was missing or got ground up on the first one and you didn't notice it the next pulley would rub hard against the top of the mandrel and fail.
