What exactly is it doing? Do you have a drop or stop in flow? If so, try one of these solutions. Clean the pump strainer AND skimmer basket. Make sure that the impeller is not jammed or clogged. Cleaning with a stiff wire brush through the pump strainer opening will usually work. The alternate method would be to disassemble and clean. You could have an air leak on suction side of pump. Check cover gasket, hand knobs, hose, clamps, etc. Replace or tighten them as necessary. Finally, it could be that your pool filters electric motor is running less than maximum R.P.M. Most motor problems are due to undersized or improper wiring, power cut backs, or a combo of both.
