Scanners How do I get the scanner to scan several documents as one group, (so that I can email them as one attachment)? Instead of individually scanning each document as separate. Then I have to attach each page separately to my email.
You must have an email program like Outlook installed on your computer. When scan to email is selected it simply opens whatever defaul email client and attaches the scanned doc to a new email message.
After you scan the first page, click on add another page or add more, or ahatever your particular program asks for to add another page. When you save as, the pages will all be in one document. If you scan each page, individually as a separate document, they will be just that, separate documents.
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
Scan the document and save the document as a jpg image file then create your email and attach the jpg image file as an attachment to your email before you send the email.
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail. If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Save the scans to a folder. Then pick each scan, individually, as an attachment to the email. Depending on the mail service you use, quite a few can be sent at one time. Hope this helps.
1.From "My Computer" right click the appropriate Brother FAX, MFC or DCP machine.
2.Select Get picture using Scanner Wizard.
3.Click "Next" at the welcome screen.
4.Select the save options that you require and click "Next".
5.The Wizard will now start to scan using the settings you specified.
6. Select the "Nothing. I'm finished working with these pictures" and click "Next".
The images will then be saved to the the location that you specified in step 4.
later you can attach the scanned file to your outlook express.
Hello, my name is Chris. Scan them to your computer. After they have been scanned, locate the scanned document. Go into your email, compose new message, and than look for an ( add attachment button befor you sent the email.) Locate the document you wish to send in email in the box that appears, and attach. than send.
