SOURCE: no signal
can you please help me?
I want the software driver for LG775FT for windows98. can you please send me through e-mail?
my e-mail is ::
[email protected]
thanks
SOURCE: monitor displaying 'check signal cable'
Make sure the refresh rate is set at 60 hertz before using the new monitor also check the display settings to see if they are set to use the external display also. Yours may automaticaly do this and your partners may not. If this does not help please let me know the type of notebook and monitor. Good Luck!
SOURCE: Nothing on the screen at startup
If you cant get into the setup menu then I would think the monitor is defective,you did not state if you hooked up the monitor to a computer that has a vga port that works.
SOURCE: when i connect my pc
Hi raposo69 ,
I see that you are having an error check signal cable.
Have you tried selecting the correct Input for the LG LCD monitor?
make sure that the Correct Input is selected properly to be able to detect the signal from the HDMI cable that you are using.
The audio will not confuse the video on an HDMI Video will be detected as long as the Input on the LCD monitor is selected.
Audio on the HDMI will only work if the HDMI driver is provided like on a desktop computer you will need to get the driver for the HDMI for Audio and video to come out using an HDMI cable but never will audio conflict to the HDMI video output.
I hope this hepls.
Have a nice day,
mvincentc
