How do I download a pic that my daughter has sent me on a Samsung GT B7510. It's saying message size 29KB expires 19 June, then when I press that another message comes up with details on it, but when I press OK it goes back to the previous message.
Some providers and or phones have a time limit on the pics sent via txt or mms. Unfortunately idk if you can recover your past pics. But the next time you recieve a pic this way, try tapping and holding the image to bring up the options menu. Then select save image or download image. This will save the image to your gallery.
These errors mean that the size of the message, including all headers,
text and attachments, exceeds the domain's maximum per-message size
limit - essentially, that the email is too big to be accepted. This means that the message wasn't sent because it was too big. You
need to take out something from the email to that it's small enough to
send.
Delivery Status means what happened with the delivery eg sent, failed.
The recipient domain didn't accept the email because it was too large.
I would advise you to send the email in 2 smaller packages.
Also:
Features Yahoo! Mail Plus Yahoo! Mail
Message size limit
25MB
25MB
Filters
200
100
POP access
Yes
No
Forwarding
Yes
No
Yahoo! AddressGuard
Yes
No
No promotional taglines in messages
Yes
No
No graphical ads
Yes
No
No account expiration
Yes
No
25MB message size
Send and receive up to 25MB per message. That means sharing lots of
photos, music, video, and presentations without worrying about bumping
up against message limits.
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account 1. Select Menu > Messaging > Email > Settings > New account > Add. 2. Enter a name for the email account, for example, Home or Office. Select OK. 3. Select Connect using > Edit and select the data account you created earlier to use with this email account. 4. Select Email address > Edit. Enter your email address. Select OK. 5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common. 6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK. 7. Select Username > Edit. Enter the incoming server username. Select OK. 8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you want to be asked for the password each time you check new mail. 9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send email messages. Select OK. 10. Select Advanced settings. 11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing email messages. 12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and select OK. 13. Select Download S&R. Choose what to download when receiving new email messages: • Subjects only – receive information such as sender and subject before downloading the whole email. • Up to size limit – receive the whole email. Select Size limit to set the maximum size to download when receiving new email messages. • Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files. 14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your email server and check for incoming email messages. 15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to disable the functionality. See Using push email for full email notification functionality on page 7. 16. Select Allow connection > Edit. Select Any network or Home network. 17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your phone to be sent to an additional email address of your choice. This way your sent messages are copied and can be saved for future reference. 18. Select Encryption > Edit. Choose whether your email messages should be encrypted. 19. Select Outgoing. username. If requested, select Edit enter the outgoing server username. 20. Select Outgoing. password. If requested, select Edit enter the outgoing server password. 21. Select Incoming port. If needed, change the port for the protocol you are using. 22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message 1. Select Menu > Messaging > Email > Write new. 2. Select To: to add recipients and select Add. There are three ways to add an intro sentence: • Select Enter email address. to enter an email address. • Select Contacts look-up to retrieve a recipient from Contacts. • Select an email address from the last used recipients. 3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished selecting recipients select Done. 4. Select Subject: to write the subject. 5. Select Text: to write the text. 6. Select Attachments: and select the attachment to add. Add more attachments the same way. 7. Select Continue. 8. Select Send to send the message or More to view options. To receive and read email messages 1. Select Menu > Messaging > Email > Inbox. • Select Send&rec when the inbox is empty or • Select More > Send & receive to download new messages. 2. Select a message and select View to read it. To reply to an email message 1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More > Reply and select: • Yes – to include the original message in your reply or • No – to exclude the original message. 2. Write your message select OK > Continue. 3. Select Send to send the message or More to view option
