SOURCE: Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
SOURCE: smell in washer SAMSUNG WF203ANW
NO is the outlet pipe fitted properly so that water cannot drain back into washer after use
SOURCE: Samsung washer is leaking water
I've also had this problem with my machine , it was my brother who found out that the soap drawer has an irregular side over which the water jumps if it pours in with strenght from the tap. that's why the leak seems to be at the front, and only at the beginning of the cycle. We supposed it has to do with using the same drawer for different types of washers. we solved it arranging the low side with american tape and some square flat plastic. Good luck.
SOURCE: Samsung Front Loader wf306law took off back panel
I found MayTag has a full report on this washer. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8169153c018494398525729c0057a4d2/$FILE/Samsung_Frontier_Washer.pdf
The part number is DC97-10417A and can be ordered at samsungparts.com
http://www.samsungparts.com/Products/Parts_and_Accessories/PID-DC97-10417A.aspx
SOURCE: I have a two month old Samsung WF350 front load
I just received my Samsung WD 8804 front loader washing machine, and during the 3rd wash trial, I noticed the same problem of water trickling down from the base of the front door. I took a closer look and the problem is actually due to a cracked rubber seal, which can be seen through the glass door. I have informed the technician.
