Sewing Machines Logo
Posted on Jun 13, 2011
I have an error e5 on my elna 6600 and was wondering how i can fix it??
Elna 6500 Sewing Machine. The reverse key only works sometimes. How do I fix this please?
Elna
Sewing Machines Plus https://www.sewingmachinesplus.com > Elna PDF Reverse Key. If you are sewing a straight stitch, zigzag stitch or 3 step zigzag stitch*, press and hold the key. The machine will sew in reverse until you.
76 pages
Elna sewing machine sews backward
Quiltingboard Forums https://www.quiltingboard.com > Main
Jul 15, 2019 - I think the lever above the stitch length knob is for temporary reverse. The knob has red numbers and black numbers. The red numbers are for ...
Missing: 6500 ‎ key
ERROR CODES
lesporteslogiques.net http://lesporteslogiques.net > materiel > Error-C... PDF With the machine off, hold down the Start/Stop & Reverse buttons, then turn the machine on. 2. Press 'Bobbin'. 3. Insert the red bobbin gauge. Press 'Key' until .
Oil or not an Elna 6600 quilters dream 2 ?
Since it is a computerized machine, oil as directed in the manual. Oiling in the wrong place could damage the machine.
2answers
I have moved house and lost my manual for my Elna 6600 Quilting Machine - Can I get a new manual or perhaps a copy until I find my own manual. thank you Jules
Well you may please follow the link below to get your manual -
http://www.sewingnz.com/products/Elna-6600-Sewing-machine-instruction-manual.html
Good Luck!!
Thanks for using FixYa!!
How to make a button hole with the Elna Quilter's Dream 6600?
it has a built in button hole, check your manual and put proper foot on machine.
1helpful
New Janome 6600 Erroring out
This is the official Janome reference to your E% error message:
Feed sensor error "E 5" appears when the machine is turned backwords slightly while the machine runs over tight spot. The above will happen when - the machine is locked by thread jammed in the machine. - sewing extreamly thick fabric. In case of the MC4900, it will happen when running without threading the thread take up lever. The thread take up lever should be threaded when the threading light lights up.
Hioe this helps
Bargain Box
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
