SOURCE: Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
SOURCE: Ice Maker
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
SOURCE: GE PFS22MISBBB freezer not cold enough. Temp won't reset.
replace the fan as quickly as possible it may be shorting and causing damage to your control board,
SOURCE: Ice Maker abruptly quit
is the ice bucket in the door ? if not and there is water or ice inthe maker and your frezer temps are right[close to 0]the its the ice maker.some maker have a moduel you can replace but the surest way is to replace the whole maker.if bucket in the door theirs other posibilties.God bless,tom
SOURCE: Amana side by side ice maker quit. verified water
Hi andy and wlecome to Fixya. There is usually a semi white plastic line that runs up the back of your refrigerator. Here are some steps you can do to verify that the water valve is actually working
You will need an old power cord or cheap extension cord with 2 female bayonet terminals on it. (Make one if you have to.)
1. Unplug the unit.
2. gain access to the water valve and disconnect the wire terminals 2 ea from the solenoid.
3. Connect the cord you made to the solenoid making sure that the 2 terminal connections will not come off or touch together.
4. Get a bucket and gently pull the plastic line from the bulkhead connector in the upper area of the back of your unit and place it in a bucket.
5. Plug the cord into the wall outlet and HOPE that water flows into the bucket.
If the water does NOT flow then the water valve is clogged and will need cleaned or replaced. Many of these water valves have a hose type inlet connector fitting from the water SOURCE. Before attempting to remove any water lines turn the water source OFF. That fitting can be removed and you can check for a clogged screen.
Just remember to remove your test cord and re-connect the chassis harness to the solenoid when your done. Also put the plastic line on the back of the unit back into the bulkhead connector.
If you have water flow thru the line then the bulkhead connector fitting to the icemaker is froze up and you can thaw that out with a hair dryer (quickly) or a fan (Slower) with the unit unplugged.
This should give you some direction on what to do. Best of luck!
