At the start of the rinse cycles, the cold water only trickles in. I've had to turn off the cold water for a few minutes and allow the trickle to stop, then turn the water back on. Now, this doesn't work. I assume the mixing valve solenoids aren't working. Is there a repair or do I need to replace the mixing valve?
Turn the water supply off. Remove the COLD water hose from the rear of the washer. Clean the silt out of the COLD water valve on the washer. Re-attach the hose on turn on the water supply.
you nead to turn off both cold and hot water.next you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back on.you should have better pressure.your rince cycle is cold water.
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
I had the same problem with my Kenmore Model 11022956102 washer and first thought that it was the water inlet valves. So I replaced them, but found the problem continued. After about 25 seconds into the rinse cycle the water only trickled in. Checking with a voltage meter I found that I lost 120V at terminals 3 & 5 on the washer temperature controller after 25 seconds. Even though the wiring diagram doesn't show the water temperature control board, since it's full of resisters and capacitors, I figured it was the most likely problem. So I ordered a remanufactured board from Parts Simple (#3407125), received and installed it. The 17 year old washer is now working fine once again. I hope this helps someone with the same problem. /s/ Paul
