Will it go through the wash cycle now? If it does, then it's more than likely the transmission. If it makes the noise in wash cycle now, it's probably the motor coupler.
This problem, or some variation thereof evidently is very common with these Whirlpool Washers! I have same problem. So far, best I have found is at
http://applianceguru.com/forum2/5958.html# diagnosis by someone who knows. What William Burk says there makes sense. However, to get to the drive block there's quite a bit of disassembly required. I am stopped because I cannot get the spanner nut off. Hope this gives you some help toward finding a more comprehensive answer
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
