We tried to reprogram our garage door opener and we are still having issues with it, the inside opener attached to the garage door opener works fine but the key-pad and the wireless openers do not work what should I do?
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
If the sensor is working right, that leaves the downward force sensor tripping. First check for track obstrucions by manually moving the door with the lift disengaged. If door works without excessive force, then increase the force sensor of the lift a bit.
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Did it work before you tried to program it?
