Question about Tilia FoodSaver V3240 verticle vacuum food sealer system
Sealer is clamped down with no way to open it without breaking it. Seal button is not lit up so it is not possible to cancel it
How do I open a stanley fatmax 5watt waterproof rechargeable spotlight without ruining the watertight seal ?????
It may not be possible if seal is stuck to either surface. Best just open it first. If seal breaks, then either replace the seal if one available or replace the unit
Dec 11, 2017 | Stanley 5 Watt Led Waterproof Rechargeable...
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - Amazon.com
www.amazon.com > ... > Vacuum Sealers
Amazon.com, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red
Amazon.com: Rival Vacuum Sealer: Kitchen & Dining
Amazon.com, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red
Amazon.com: FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Printer Problem
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
power off and open front door
hold down the continue button as you power on printer leaving front door open
when error light comes on release continue and close front door.
toner low, load paper, ready, and continue will all be lit.
press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change
when just toner low is lit, press and hold continue button until lights cycle up and down in sequence.
release continue.. toner low will be lit again
turn printer off, wait 10 secs or so and then back on
press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Apr 09, 2014 | Dell 1720dn Laser Printer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
1989 toyota 4x4 pickup, 22re engine, was leaking water out the tail pipe, so am trying head sealer....now when it got low on water the idle would go up and down, up and down. put water in it and it would...
There are no codes need for this they have limited definitions,so lets leave it alone.If you want to sucessfully put a head sealer the direction says to put in radiator. I hope you did use the block sealer just yet. since you replace waterpump and thermostat you can do this, this is the proper way to use block sealer remove the thermostat take some fluid out and pour you block sealer in there. add you coolant or water, and put the thermostat back in.closed the system back up top off the radiator. Not this will be tricky and you ll have to under stand the process or you will waste the block sealer,okay? first because when you are low on coolant this indicates how blown the headgasket is the combustion is coming out to the radiator and with fluid in the radiator the combustion that should go out goes out due to fluid in the radiator okay. block seal in radiator top off. you will use the upper radiator hose as an indicator of how successful you made the repair.start the engine in order for the block seal to work it works and seal because of heat it goes to the hottest part of the leaking area because its hot it solidifies and thus the seal.Start the engine have it rev to 1500RPM feel the upper radiator hose and keep the RPM up. Now when the upper hose feels like it collapse or is soft when squeezed add your coolant or water in the radiator keeping RPM high and dont lower when you open the thermostat it will just shoot out. Now if your repair was sucessfull you upper radiator hose will be solid when it is solid dont open it will shoot out. watch you temp gauge is it close to 200F or kinda in the middle, when it get there shut down the vehicle and dont open the thermostat why because you head is blown and the sealant will just get shot out into the exhaust. so let it seal as it is leaking out and eventually it will seal, now when it get cool open the radiator fill it up, restart feel the upper hose again rev it up to 1500RPM, does it get solid as the engine warms up?if it does you suceeded.If it doesnt you need to repeat or replace headgasket
May 12, 2011 | 1989 Toyota 4Runner
Where is the thermostat located on a 2005 pathfinder
Look at the upper radaitor follow it back to were it clamps to the engine . This part is called the goose neck the thermostat is located under this part.Its not a hard job to do you need to drain some antifreeze not all of it a couple qts open the pitcook in the bottem of the radiatorcacth it in a bucket because you can reuse it if its clean. Take the clamp off the goose neck twist the hose to break the seal move it out of the way Remove the two bolts that hold the neck down you will have to break that seal to pry it gently with a screw driver handle that fits into the water inlet remove it and you can lift the thermostat out. Clean bolth gasket surfaces all of the old gasket needs to be removed you can use a razor blade try not to nick the surfaces these parts are aluminun and if not completly clean may crack when tightening or leak . Install new tstat new gasket a must you can use some sealer that helps to hold the gasket in place install bolts to 18 ft lbs don't try to over tighten the gasket will make the seal.Install the hose and clamp add the antifreeze start and check for leaks. And antifreeze is good for 5 or 6 years or 100,000 miles witch ever comes first then need to be replaced most people think it lasts for ever trust me it dosn't and yours is comeing up on 6 years Good luck
Jan 06, 2011 | 2005 Nissan Pathfinder
How to operate a Salton vacuum bag sealer?
HOW TO MAKE A BAG
1. Place the BAG SEALER on a firm level surface adjacent to a power supply socket. We suggest the bag sealer be positioned away from the edge of the work surface allowing plenty of clear space for making the bags.
2. Take the polythene roll and insert it in the trough in the sealer, positioning it so that the film is pulled of the roll from the underneath.
3.Polythene roll supplied by Salton (Cat No. 1121) is a high grade film suitablefor use in a microwave oven, boil-in-the-bag cooking and for storing in the freezer. Replacement rolls are obtainable from stockists, or in the case of difficulty, from Pifco Servive Department.
4. Plug in to mains supply socket and switch on.
5. To make the first seal on a new roll of polythene, lift up the cover and pull out enough film to project an inch (2.5 - 3 cm) or so outside the casing.
6.Now press the lid down firmly so that both the red and green indicator lights come on. In a short time - approximately 6 seconds - the green seal light will go out. AS soon as this happens lift the lid and peel of the film.DO NOT ATTEMPT TO PEEL THE FILM AWAY BEFORE THE GREEN SEAL LIGHT GOES OUT.
7.NOTE - when closing the lid and applying pressure two distinct clicks will be heard.
theses are the switches which operate the two functions of the BAG SEALER.
First click - Operates the air extraction motor. Vacuum light (RED) ON.
Second click - The sealing wire is energised. Seal (GREEN) and vacuum light (RED) both on.
8. We suggest that you famillarise yourself with the pressure mechanism before you begin using your BAG SEALER. It is perfectly safe to operate either the seal or vacuum functions with out using any polythene roll.
9. After several uses deposits of polythene on the sealing wire can reduce the effectiveness of the seal. Theses deposits of polythene can be removed by operating the seal mechanism without any polythene across the wire.
10. Having sealed one side of the bag, pull out the film to the desired bag width (MAXIMUM WIDTH is 2.9 cm / 11 1/4 inches) and seal again by closing the lid and pressing down hard.
11. As soon as the Green seal light goes out, lift the lid and peel the bag away. Ensure no film adheres to the sealing wire.
12. This seal creates your first bag and at the same time the first seal for the next bag.
SEALING A FILLED BAG (WITHOUT AIR EXTRACTION)
1.Make sure that no food or liquid remains in the top portion of the bag close to where the seal will be made as this may effect the effectiveness of the seal.
2. Place the open end of the of the bag over the sealing wire making sure that the film is flat WITH NO FOLDS OR CREASES ALONG THE LINE OF THE SEAL.
3.Close the lid and press down firmly to make the seal.
EXTRACTING AIR FROM A FILLED BAG.
REMEMBER: Do not extract air from bags containing liquid !!!
1. After filling the bag and making sure that the sealing area is free from food particles, place the open end of the bag over the sealing wire and place the black air extraction nozzle well inside the bag. It is important to ensure the the two edges of the bag under and over the nozzle are straight and not creased in any way to ensure an air tight seal !
2.Depress the lid gently until the red light comes on and hold this position to operate the air extractor. (DO NOT press so hard as to activate the the green light and therefore the sealing wire).
3. As the air is being extracted it is sometimes of help to hold the bag with your hand and gently move the contents around to help channels of air to form, so aiding extraction. Depending on the the nature of the porosity of the food some unavoidable air pockets may form but moving the contents around these can be minimised.
4.Once all the air has been extracted increase the pressure on the lid until the green light comes on. This must be done in one continuous movement, otherwise the air might seep back into the bag. Once again the bag should not be pulled away from the bag sealer until the green light goes out. Pressure on the lid should be released, the lid lifted and the bag peeled away.
LAMSBREAD :)
Sep 27, 2009 | Kitchen Appliances - Others
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a yellow blinking toner cartridge light. Neither the continue or cancel lights are lit up. This...
Sounds like your photocoductor is at lifes end. You can reset it by doing the following
1. Turn the printer off.
2. open the front cover
3. hold down the cancel X button while turning on the power and keep holding down until all lights stop flashing. Then let go of the x button and all lights should start to flash, close the front cover...and it should reset. You may have to turn the printer off and then back on once to be sure it is reset.
Jul 07, 2009 | Lexmark E232 Laser Printer
Tilia FoodSaver V3240 verticle vacuum food sealer system Logo
43 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Sheldon Dedek
Vitally Alcher
Bonard Allen
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
