Microwave Ovens Logo
Posted on Jun 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My model Microwave KOT-1515 about 8 years old was not heating. I pressed the power pad and all that shows is a little dash on the screen. I cannot reset the power, and the micro won't work at all. What should I do?
Anonymous
Level 3:
  • Master 1,902 Answers
  • Posted on Jun 11, 2011
Anonymous
Master
Level 3:
Answers
1902
Questions
0
Helped
533822
Points
5669
Hello & Welcome to FixYa
The problem is either with the a loose broken connection inside the unit or with the door switch that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
How do I set the microwave for 50% power?
Hello, Linda -
Without knowing the make and model of microwave oven you are asking about I can only give general instructions. You can add the make and model of microwave by choosing Comment and adding the information there.
Generally, after placing whatever you want to heat or cook in a microwave save dish or on a microwave safe plate and place the food and dish inside the microwave and closing the door, you follow these steps:
- Using the key pad / number pad, press in the time you want the microwave to run
- Assuming there is a POWER button on the key pad, press that button
- Most likely a P will display
- On the keypad, press 50 (for 50 %) or maybe just 5
- Press START
This web page provides detailed instructions:
https://www.leaf.tv/articles/how-to-adjust-a-microwaves-cooking-power/
Best wishes.
What is the Serial Number for the EWAVE KOT- 17sb? It does not display it in the information panel.
Hello, Marisel -
Do you mean the Daewoo KOT-170SB microwave oven, instead?
The manual for the KOT-170SB microwave I found online (PDF format):
pdfstream.manualsonline.com/1/1d0dd7b3-990b-4256-9519-fa2dc1e7c2bf.pdf
shows a "data plate" on an interior wall of the microwave (page 7.)
That may be where the serial number (S/N) for the microwave is printed.
If not, there may be a label or tag at the back of the microwave oven where the serial number (S/N) is printed. Or, there may a label on the back of the microwave oven, look on the bottom.
Best wishes.
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
how old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
1helpful
E Wave microwave stop heating
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
1helpful
E-wave microwave model #kot-131uw just quit all of a sudden
Is it dead, meaning no display, no light when you open the door and no beeps when you press a pad on the keypad
Top Daewoo Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
