Bought and replaced batteries in remote. How do I get the van to recognize the remote. ( The other remote still works). Also, will I have to reprogram both remotes?
I am having the same issueI am having the same issue
AnonymousMar 12, 2014
i bought a 2003 caravan, ordered a remote off ebay ( 502 astro start )but don't know how to program it for my vani bought a 2003 caravan, ordered a remote off ebay ( 502 astro start )but don't know how to program it for my van
You can't post conmments that contain an email address.
Believe it or not, the information and instructions for reprogramming your particular model of vehicle is provided in your owner's manual. The dealer does not need to be involved unless you have lost all your programmed and programmable keys.
It does indeed have keyless entry. It needs reprogramming when you get a new remote. Also if you disconnect the battery. Usually a local car alarm fitting shop, or an auto-electrician will do it. Plus of course a Ford dealership.
You did it like this ?
Programming -Keyless Entry Remote Transmitter
NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time. NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered. NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock. 2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A. 3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum). 4. Turn key off. 5. Remove the short from the program connector. All doors should lock and then unlock. 6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming
programmed at the same time. NOTE: To program (or reprogram) the keyless entry remote transmitters
into the RAP module, perform the following steps:
Make sure that the anti-theft system is not armed or triggered.
Turn the ignition switch (11572) from OFF to RUN eight times within ten
seconds, ending in RUN. If the RAP module has successfully entered program mode,
it will lock and then unlock all doors.
Within 20 seconds, press any button on a keyless entry remote transmitter,
remote transmitter has been programmed. Repeat this step for each
transmitter.
wait several seconds and press the button again. If the door locks still fail to
respond, refer to Inspection and Verification.
Turn the ignition switch to the OFF position, or wait up to 20 seconds after
step 2, to exit program mode. If a keyless entry remote transmitter has been
programmed (or reprogrammed), the RAP module will lock and unlock all doors one
last time to confirm.
Programming Electronic Door Lock Control System
NOTE: The electronic door lock control processor (14B001) erases all
previous keyless entry remote transmitter (15K601) from memory when the keyless
entry remote transmitters are programmed or reprogrammed. The electronic door
lock control processor can store up to four keyless entry remote transmitters in
memory.
To program (or reprogram) keyless entry remote transmitter into the
electronic door lock control processor, perform the following steps:
Turn ignition switch to the RUN position and momentarily short the two
terminals of the program connector taped to the wire assembly and located behind
the glove compartment. All doors should lock and then unlock. Remove shorting
pin.
Press any button on keyless entry remote transmitter. All doors should lock
and then unlock to verify the keyless entry remote transmitter has been
programmed. If door locks do not respond, press button again (up to three times
Repeat the above step to program additional keyless entry remote transmitters
into the electronic door lock control processor (up to four keyless entry remote
Turn ignition switch OFF. All doors should lock and then unlock.
if its factory keyless entry, chances are your battery for your remote need to be replaced, the remote could also need to be reprogrammed... If it is an after-market system, there are several possibilities... wires could be pinched, the door lock solenoids could be broken or misaligned, the "brain" of the system might need to be reprogrammed.
i went to program and it doesnt lock unlock after the 8 turns any ideas?
