TORK 711A  24 Hr InWall Electromechanical Timer  24 OnOff Cycles  15A Logo
Anonymous Posted on Jun 10, 2011
Hi I have a Tork 711a timer but do not know how to set the on and off times. Is it possible to have an instruction manual emailed to me?
A
Anonymous
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jun 10, 2011
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3071211
Points
27242
1helpful
To re-program a Tork dg-100 digital timer switch
Using http://www.google.com you can find some manuals for free on the internet. Be wary of ones asking you provide an email address that may be malicious in intent.
Note the suggested answers shown below this FIXYA question that may provide further assistance to you. Not all are relevant to your model.
https://www.manualslib.com/manual/1050789/Tork-Dg100.html#manual
Tork DG100 Instructions Manual
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html
2) Tork TU universal
http://waterheatertimer.org/How-to-set-timers.html
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
How to set tork outdoor timer model no.sa0022
Timer is not identified.
1) Copy following links to help identify SA0022 timer:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
2) Add comment and describe timer in exact detail so expert can possibly identify same-similar manual
INSTRUCTION MANUEL FOR Tork 654A Digital Outdoor Photocell Timer
Copy following link to identify 2-outlet, dawn-dusk, Tork 654A digital timer and download possible manual, and read instructions.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#outdoor
Also sold as GE 15255:
http://waterheatertimer.org/GE-timers-and-manuals.html#outdoor
1helpful
2answers
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
2helpful
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
1helpful
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
I have a w100 tork timer and i would like to know how to repair it and how to position the time pointer.
How to position time pointer
Rotate disk counterclockwise until current time lines up with silver pointer
Place trippers on outer edge of dial > trippers are reversible so one side of tripper in ON > flip tripper over and it is OFF.
Disk rotates with passing time, trippers click lever ON and OFF at set times
How to repair W100:
If dial is not rotating, then clock motor is bad >> W100 uses 120V clock > check markings on clock. Internet shows Tork T101M and T201M clock motors, but unclear if either clock matches W100 timer.
If dial rotates but trippers do not turn Load on-off then buy P-69 trippers
If manual override turns Loan on-off then electric circuit is working
If manual override does not operate Load, then check electric circuit or Load (light bulbs burned out)
If manual override is sluggish or stuck, and doesn't click crisp and clean, then timer is worn out or needs to be cleaned.
Product Manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html#W-series
Link above shows manuals
Manual for W100 does not show specific clock-motor model
To buy parts or another timer
P-69 trippers available on web
Tork T101M and T201M clock motors available on web but unclear if they match W100
http://www.weisd.com/store2/tork/torktimer1.php
Page above sell W-series time dial part #70159 for 72$.
Page does not include photo, so unclear if dial includes clock-motor, or if voltage is 120V
Tork accessories pdf shows part #70159 as dial for W, with no other information
Same seller shows new W100 sells for $148.
Replace Tork with Intermatic, buy T7401B
Website sells T7401B for $114
T7401B is 120V timer and has 120V clock motor
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Manual for T7401B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
I don't know how to set the timer to come on a 7 pm, off at 11 pm. It is a tork 1103 electromechanical timer. Directions lost years ago and new homeowners (myself) do not know how to set the timer. Anne
See T1100 Tork timer on following link:
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
To set this timer, rotate clock dial clockwise until current time lines up with the word 'TIME' located at 5 o'clock position.
Place black and gold P47 trippers at times you want timer to turn on-and-off.
As time passes, the dial rotates. ON tripper flips a lever that turns Load ON, and then later, the OFF tripper flips same lever and turns Load OFF.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Top TORK Hardware & Accessories Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
