AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
Posted on Jun 10, 2011
I have a F86070VI. When turned on all of the cycle selection lights come on and pressing the reset two does nothing. There is no display in the time window. Have turned off at mains and left; turned on again with same error. Regards Michael
How to solve E000001-0002 canon ir3300 error code
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ [email protected] if you have any questions.
1helpful
Electronic panel freezes!
In reference to Kenmore washers in general:
Most washer's can be reset like a personal computer.
If the appliance does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  • Press the Pause / Cancel / Stop button twice to clear the display.
  • Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the appliance, that requires service
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
1helpful
Can't select wash cycles
Is the control board displaying any fault codes?
Try disconnecting the power cord to the washer from the wall outlet for 5 maybe 10 minutes...give the control board enough time to power down and hopefully the control board could self-correct itself by resetting. No different than re-booting a computer.
If you still run into the same problem, and if so equipped, try holding down the "end of cycle" signal button for 10 seconds and see if that resets it.
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
E68 error code
This E68 is a stuck keypad.
The error E68 means the CCU has sensed a stuck button on the console. MANY times this is a false error and means that either the CCU or interface must be replaced, but SOMETIMES, there really is a stuck button. Try to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1 time and " res" will be shown briefly in the display.
come on.
Key test:
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the interface OR CCU, but in my experience, it's usually the interface that ends up needing replacement. Here is a link to the interface board.
1helpful
Ir6000 error code e246-0002
press the #2 and #8 at the same time (simultaneously)
Select copier
select clear
select ERR
press OK
****IMPORTANT****
2helpful
Low tire pressure reset selection missing from reset program
Turn ON the ignition, with the engine OFF.
Cycle the exterior lamp switch from OFF to parking lamps 3 times within 5 seconds.
Use the scan tool in order to clear the TPM DTC.
Using the RDS radio, if equipped
Adjust all tire pressures to the recommended kPa/psi. Refer to Tire Inflation Pressure Specifications in Maintenance and Lubrication, or to Tire Placard in General Information.
Turn the ignition to ACC or ON, with the engine OFF.
Turn the radio OFF.
Press and hold the DISP button until SETTINGS is displayed.
Press the SEEK up or down arrows until TIRE MON is displayed.
Press the PREV or NEXT button to enter the submenu. RESET will be displayed.
Press the DISP button, A chime will sound and DONE will be displayed.
Scroll until EXIT is displayed.
Press
How do I reset my 2008 Honda Accord oil %
Honda Accord 1998-09 To reset MAINT REQ’D light, press and hold select/reset button on right side of instrument panel. Turn ignition on and hold until the light goes out.
On the right of your dash is a pair of buttons, one for selecting/changing the odometer and the other for cycling from MPH to KMH and back.
Turn the key on.
Push the select button until your display indicated the remaining oil life percentage. When it is displayed press and HOLD the select button until it begins to flash. Once it starts flashing release the button and press and hold it again. The display will clear and if you release the button and cycle through the display with the select button you will see oil life 100%. Good luck and this should reset the oil life.
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
