SOURCE: I have a Frigidaire FTF530FS washer which is new.
Hello
& Welcome to FixYa If
it is a brand new washer then it's better to get this repaired under warranty.
The problem is with the door lock assembly that is bad and needs replacement.
The drain filter pump assembly located inside the bottom front access panel
seems clean, timer motor seems to be working fine. Please get back to me if you
have any other questions. Kevin
Good Morning kvojik, thanks for your post!
From my understanding your Frigidaire front load washer is getting stuck between the drain and spin cycle. I noticed that you have replaced many components within your washer and continue to experience this issue. I would not advise to manually advance any part of the washer because this could cause issues within your washer. It could be a potential issue with the motor. At this point you may want to reach out to a technician for proper diagnosis and repair. This will help you to avoid any further part purchases. -Matt
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
