Question about RCA L32WD22 32 in. LCD HDTV
Hi, I have an RCA HDTV SRS WOW Model RCA L32WD12YX5, Serial G482CJ060. It powers on and has sound for about 15 minutes then shuts itself off and restarts with no sound. As an experiment, I used the Menu to turn off the internal speakers, and it did stay on longer, about at least a half an hour, before turning off and restarting again. Once it turns off, it starts shutting off and on very frequently. If I use the remote to restart it after the first time, the sound will come back on sometimes.
  • RCA Master
  • 8,457 Answers
The tv main Tuner signal board have problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Posted on Jun 09, 2011
6ya staff
SOURCE:
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
RCA 50: HDTV, just started shutting itself off and won't come back on for several minutes or over an hour what could cause this
My friend had the same problem. There is some display bulb that is on its way out. They aren't cheap. Find a 2nd hand TV parts/repair shop, They usually have cheap used ones from discarded units, and will know what you need!
Sep 16, 2012 | RCA Televison & Video
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W20 TV powers on fine, then shuts itself off after 5 - 10 minutes. After 20-30 minutes, I can turn tv back on, but then shuts off again in 5 minutes.
it looks like the problem is in the 16v line..try to take it apart..and there's gonna be a 2200mf cap leaky.
that will solve your problem.
Jan 05, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA SRS Wow problems.
my pic has 1 1/2 in on each side that is black
Sep 07, 2009 | Televison & Video
RCA HDTV MODEL # D52W20 SHUTS OFF AFTER 10 MINUTE.
There is a common power supply problem with these that requires the replacement of four capacitors on the power board. This could be causing your problem.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
RCA TV
Solder bad connections...main board with hv transformer on it..
CL035 capacitor and any others...use magnifier........T.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound Fades, then TV shuts off then continues to recycle on & off
Sometims several capacitors start going bad giving you the audio problem, but I don't remember the set turning itself off. That could be a secondary problem around the flyback transformer which may have a bad solder connection. I would check that first. Otherwise, I would be tempted to go with HDTV.
May 29, 2007 | RCA F36685 36" TV
RCA L32WD22 32 in. LCD HDTV Logo
427 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
