Hello,here is how to replace or change ink cartridges:
1. make sure the printer is turned on.
2.lift the top cover or access door.
3.press down on the cartridge level to raise cartridge lid.
4.remove cartridge(s).
5.for new inks,remove the tape from the back and bottom of cartridge before you install it.DO NOT REMOVE NOR TOUCH THE COPPER CONTACTS OR NOZZLES ON THE CI have a Lexmark Z2390 - sayurisan20_23.jpg
6.insert black cartridge in the left slot and the color in the right.
7.close the lid anI have a Lexmark Z2390 - sayurisan20_24.jpgclosed properly.
8.close the access door.
you can align them to improve print quality by clicking on start,all programs or programs and then click on the lexmark folder,click maintenance,align cartridges,then print.
Watch this video from You tube @ "Replace Ink Cartridges in your Lexmark Printer"
Hope it helps.
Video Link @http://www.youtube.com/watch?v=nLFAubGBD...
1. Look at the indicator light on your Lexmark printer.
You'll need to replace ink cartridges when the light flashes or turns red
instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand
name or purchase a generic version that is compatible with your printer. You
can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the
sides of the Lexmark ink cartridges and pull it out. Dispose of the ink
cartridges in a recycle program like the one at Staples or save the cartridges
for refill.
4. Install the new ink cartridges after removing the
protective tabs. Avoid touching the IC chip when installing the new Lexmark ink
cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print
several pages with the new ink cartridges to make sure you installed the ink
cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
