Verbatim 1TB USB2.0 HDD USB 2.0 Hard Drive Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Verbatim model #47512 1tb makes this beeping sound every time i connect it to my computer why?
Azrael SRL
Level 3:
  • Master 11,800 Answers
  • Posted on Jun 09, 2011
Azrael SRL
Master
Level 3:
Answers
11800
Questions
0
Helped
2564677
Points
35672
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
2helpful
I have a verbatim 320GB externam hard drive the model is CLON320GB. One day it just stopped registering on the computer. At first it woulod make a constant beeping noise when I plugged it in but would not...
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
1helpful
My portable hard drive wont connect to my computer. When I plug it in a blue light on the device light up, and it makes a constant beeping sound, but my computer does not register the device. It works on...
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
2helpful
2answers
Computer does not read Verbatim #47562 at all. Does not show up even on disc management.
And does it make any sort of clicking sound when connected to the computer?
Either the drive itself is faulty, or the enclosure transforming the drive's interface to USB is not working.
You could always try taking the drive out of the enclosure and connecting it directly to your computer's hard drive interface, but be very careful not to damage anything.
3helpful
2answers
My verbatim model 47562 connects via usb and powers up, but nothing is detected by the computer at all and it does not show up. Need help urgently to recover all data please.
First of all try to:
- use a different usb cable to connect it
- connect it to a different computer
- connect it to a different USB port (preferably one in the back of the PC, not in the front plate)
If still isn't working, could be the electronics of the verbatim HDD case, you can try to open it, take out the hard drive and connect it directly to a desktop pc via SATA inteface. This can be tricky, so let me know if you need further assistance in doing that. You may need an adapter, depending on the HDD interface your desktop pc has
If unfortunately your drive is making mechanical repetitive clicking sounds it could be broken. If the data is very important to you, you can rely on companies like this:
http://www.ontrackdatarecovery.com/
to have it recovered, be warned though that the price will be expensive (about 1500$) so see if it's worth it.
Best regards
2answers
I CONNECT EXTERNAL HARD DRIVE TO PC WITH XP AND IT DID NOT RECOGNISE EXT HARD DRIVE HELP PLEASE
dear sir
good day
try to replace the USB cable and test the Hdd on an other computer system to make sure it is function and good luck
Hp computer will start, all the lights come on but the screen is black.. also.. it makes this loud beeping noise 4 times?? whats wrong?
The beep is more than likely a beep code (sounds stupid and obvious, but they're there for a reason).
What make/model is your machine? We can look up the code by make/model. That will diagnose your problem.
Top Verbatim Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Obehiaghe Adoghe
Obehiaghe Adoghe
ExpressFiX
ExpressFiX
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
