Jenn-Air JES8850 Electric Kitchen Range Logo
Posted on Jun 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 8114p732-60 control panel doesn't work only the time is displayed
Anonymous
Level 3:
  • Master 600 Answers
  • Posted on Jun 09, 2011
Anonymous
Master
Level 3:
Answers
600
Questions
0
Helped
159058
Points
2012
Hello. We replace alot of control panels on this unit,the panel which includes the touch membrane.Not the clock behind it. Hope this helps....
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
My CD drive doesn't work
Your display adapter is the component of your computer that allows your monitor to work. On the operating system side of things, this display adapter is controlled by a device driver. If you're having issues with your display adapter (like colors are displaying incorrectly or the screen is flickering), you can fix these problems by rolling back your device driver using the Windows Device Manager.
Open your Control Panel by clicking "Start" and then "Control Panel." Click "System." Click "Device Manager." Scroll down to the "Display Adapter" heading. On a single monitor setup, there will only be one device listed under "Display" adapter. Right-click it and click "Properties." Click the "Driver" tab. Click the "Roll Back Driver" button. This will uninstall your current display adapter driver and reinstall the last version that worked properly. This will fix the issues you were having with the device. Hope this helps
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 • Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Air conditioner display screen doesn't light up
The Control panels go bad. Check with your local salvage yards. They may have a used one, but can probably get you a reman, which is a better choice. In the mean time try hitting it on top of the display a few times. It will probably come back to life.
2answers
Hi i have Frigidaire electric stove model# ples389ecd stove part works oven displays f 30 and half of key panel doesn't work. Replaced board, key panel , probe still have f 30 problem and key panel...
Hi u_odil,
The F30 on your display means that your oven thinks that your oven sensor is shorted. It's either a bad oven sensor or a bad display relay control board. You can't test the board but you can test the sensor. Open the door and remove the 3-4" long thin metal rod attached to the back wall. There are 2 screws holding the sensor on that you can remove and then pull the sensor forward until you can disconnect it. With a multimeter, check the resistance of the sensor at room temperature and it should be about 1080 ohms. If it's not, replace the sensor, otherwise you need to replace your relay board.
Hope this helps.
Thank you for using FixYa.
2helpful
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Display functions on right side don't work as well as the fan
Hi drnelson3,
This problem is as a result of a bad control panel. The control panel controls all the functions of the unit it accepts commands and executes them. Often times it would accept a command but not execute as a result of malfunctions on the control board. This is why a times it comes on and doesn't function. The control board is not totally bad but suffers from partial failure therefore the problems.
Best solution is to get the control board replaced this can be done by any service repair personnel or simply contact the nearest dealer for a repair person.
Hope it helps.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
