Whoever designed that setup should have been shot on the spot! You have to get the bulb in correctly with the notch going into the correct position in the socket-real pain in the azz! Also, the cob job wire spring will pop off because of the quality engineering of a single screw holding it in place. Make sure the screw is tight. This is a prime example of 4 years of engineering college! A kindergardener could have done better!
