SOURCE: Leaking from fill level float riser Maytag MDB6000AWW
Agree 100 pct. After close inspection of the float assembly I passed on its removal and opted for the very high tech solution of using the top of a spray paint can as the overflow drippage receptor. It does evaporate within 24 hours.
We may try another soap when we run out of the Electrosol tabs we have.
SOURCE: leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
SOURCE: KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
SOURCE: Brand New overflows PLD4555RFC3
If this is new construction or a new disposal, check the hose that drains from the dishwasher to the disposal - the installer may have forgotten to remove the plug when they connected the hose.
