When was the last time you cleaned you drain filter? That should be done routinely .. If that's clogged then the the sediment from other cycles just gets redistributed on your dishes.. You might also check the washing arm that spins for debris or clogs.. Try cycling it without any dishes a few times to see if all the water drains out after a cycle.. That will help you identify if its a drain problem or if the system needs other service.. Hope that helps !
