Did you check to make sure that the electrical bridge is in the right position. If you had the unit winterized, some technician turn the bridge over which does not make an electrical connection.
Open the electrical box that should be within 6 feet of your exterior condensor unit. There is a handle plastic handle there that is attached to the electrical bridge. Pull straight out and rotate 180 degree and reinstall. If that doesn't correct the problem then reverse it again and reinstall.
Hello, most likely youmhave a bad capaitor or bad fan motor. If you push the fan and it gets going than the capacitor is bad,if not bad fan motor.
