My audio driver is not properly working. - Computers & Internet
  • 1,140 Answers
Do you have the right driver for your audio...
here...
just download this software,no need search engine,no more tired of looking anywhere...instantly,it will be in your laptop for several minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
Posted on Jun 08, 2011
My Driver Not instillation So Please My Problem My Motherboard mtq45mk
Posted on Sep 18, 2013
Anonymous
SOURCE:
I have no sound and i can not see the volume control
It's a possible problem with the driver or the sound card may be disabled. To check if the sound card is disabled or drivers not installed,
1. Right click on "My Computer" select "Properties"
2. Click "Device Manager"
3. From the list, you should see a "Sound Controller" and if you click on the drop down arrow beside it, you should see the audio driver installed(ex. High Definition Audio Device... audio driver name may vary depending on the brand of the laptop).
4. Right click on the sample "High Definition Audio Device" then select Properties. If it says device is working properly then there shouldn't be any problem with your audio.
** If the Sound Controller is NOT installed properly you need to download the Audio drivers from the support site of your Dell computer, http://support.dell.com , be sure to select the correct model of your laptop and operating system of your computer. Once you have downloaded and installed the drivers, Audio should work fine not unless it is the hardware itself that is damaged.
**Also don't forget to check if there are other external audio output devices connected to your computer, please do test if working properly.
Hope this helps. Glad to be of service.
Nov 23, 2011 | Dell Computers & Internet
Its not accepting previous audio driver which
First uninstall the previous drivers properly. Reboot the machine and try loading again. It does work wonders this way. Have patience.
May 20, 2010 | Compaq Audio card Sound Card
Pci device drivers are not installed on my system i dnt know how to install. Due to this my audio device is not working
there no audio driver install at your pc that is why your audio not working the best thing you do is, intall a pci audio driver at your pc after that your audio will work properly
May 09, 2010 | Computers & Internet
My audio is not working
You can check your audio by using these steps.
1. If you have speakers, check if it is plugged properly into your audio port which is the port with the "green" color. Check your speakers if it is turned on, put to low volume, or no power or check your audio settings on your computer if it is muted.
2. If step 1 doesnt make your audio work, you should check if your computer has audio driver installed, it depends on the manufacturer which audio driver should you install. if it is built in audio, you could use the mother board driver cd.
3. If still your audio is not working , you may have problems on your device. If you have external audio device, you should try to check if it is plugged properly on your motherboard. If still doesnt work. you should buy a new one..
Hope this will help you out. =)
Jan 02, 2010 | Computers & Internet
Audio driver not working properly
Your audio drivers is corrupted you have to download new drivers from any drivers website and you can download from www.driversguide.com
Aug 07, 2009 | Microsoft Windows XP Home Edition
My hp computer motherboard driver is not working properly its vga ,lan driver and audio driver are not working properly can u pls provide the driver for HP dx 6100 mt
Here is the web page for your vga, lan and audio drivers:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=+HP+dx6100+mt&submit.x=6&submit.y=6
Regards,
Graemevm
Apr 28, 2009 | Computers & Internet
My i install server 2003,it show a message sigmatel audio driver doesot work properly. i use intel LGA775 motherboard
  • the sigmatel audio driver it is your audio driver not work properly. first thing to do get the installer of your computer or cd driver of your computer. then insert into a cd-rom of your computer. then open the file of the cd driver of your computer then find the installer audio driver. then click the executable file wait until finish to install the audio driver.
Mar 12, 2009 | Computers & Internet
I want to download conexant hd audio 221 xp c770tu diver how can
The headphones would not be the issue unless they came with an actual software cd included. If your audio Drivers are not the correct ones for your audio device on your computer, download the proper ones. Best way to find out what you have is to look under Device Manager which is in Control Panel, Under the System>Hardware Option in the Control Panel Folder.
Verify that your device is working properly. If it is working properly. and All other audio options, like Speakers work, then the Headphones are malfunctioning and you will need to contact the manufacturer.
If no audo works at all but the Device is listed as working properly, then you possibly have a damage audio jack port
Jan 20, 2009 | Audio Players & Recorders
C797VU not working properly on Win XP SP2
ihave compaq c797vu model
for audio headphone and speaker use conexant smart audio 221 driver,it solve your problem
i have problem of touchpad ,do u have proper touchpad driver and how to confiqure,please tell me
Oct 29, 2008 | Compaq Presario 700 470024-192 Notebook
Sound card drivers for win xp-sp-3
i have installed windows xp ser: p3 and my sound card is not working
Dec 05, 2007 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
1,957 people viewed this question
Ekse
Marvin
Marvin
