Amana ACO1860 Microwave Oven Logo
A
Anonymous Posted on Jun 08, 2011
Everything works, clock, timer, lights etc. When I put in the time and press start, lights are on and cook time starts, but there is no sound and no cooking. Thanks
Anonymous
Level 3:
  • Amana Master 43,501 Answers
  • Posted on Jun 10, 2011
Anonymous
Amana Master
Level 3:
Answers
43501
Questions
0
Helped
10842847
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
2answers
GE SpacemakerXL, model #JVM1330BW 002, does everything but run
it could be a defective thermal fuse,h.v. cap,h.v. diode or the magnetron tube are defective
Enter time & press Start the timer begins but no heat
Sounds like you have a bad door switch. make sure each button on the top of the switches snaps back up after it is puched down. Also, look at the wires where they push onto the switches. if any of the plastic insulators look brown you have a bad connection there and will need to replace the switch and the terminals going to it.
Will only defrost, and not cook on high
What is the make and model number?
Eric
67helpful
7answers
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Keypad Problem?
look on the back panel for any hole with a "RESET" label next to it. insert a small pin to reset your microwave
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
