Unscrew the screw under Annie, then pull on the top part of Annie to reveal another section where more batteries go. put water in the hole on top of Thomas, not the funnel, but there's another small hole on the top of Thomas. Now Thomas will puff steam! You are lucky to have found this train, he is super fast and very unique because he puffs the steam! we have one, unfortunately my youngest son broke the chassis that connects Thomas and Annie, so it no longer works properly. You will need a dropper to put the water in Thomas.
James the train has a tender attached to him. On top of the tender there is a black plastic piece that looks like coal. Slide the black plastic piece towards you and you will see the battery underneath it.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure" http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
Take the screw out of the bottom front remove red plastic panel by lifting up on the front, this will allow you to lift front wheels up and to the rear, remove center wheels press the tabs on the left and right side in and remove the cab. One AA battery, reverse steps taken and begin playing.
Take the wheel base of the train in one hand. Point the' face straight up. Place your other hand on the top with you index finger on Thomas' face. Push down towards the ground with the hand on the top, and then pull apart. There is a little tab on the back that you need to get over. Some times the first time is the hardest.
