This feature used to work. I noticed last week however that the date was not imprinted on my printed pictures. I checked the user's guide and went into the setup to enable it and as I scrolled down the menu list it jumped over the date stamp option not allowing access to this feature that I had just 6 weeks ago.
Using the Capture Menu
The Capture Menu allows you to adjust camera settings that affect the characteristics
of the images and video clips you capture.
1. While in Live View or Playback, press , then use to highlight .
2. Use to highlight a menu option, then press to display the menu option's
sub-menu.
3. Use to highlight a setting, then press .
4. Press to exit the Capture Menu.
For on-camera information about an option, use to highlight Help... in the option's
sub-menu, then press .
In the capture menu goto
Date & Time Imprint Imprints date in lower left corner of image.
Off Default No date or time imprinted on the image. (this setting)
Date Only Date permanently imprinted.
Date & Time Date and time permanently imprinted.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
You can disabled the Date Imprint. In this option you can print your pictures without the date and time printed on it.
All you have to do is set the Date Imprint on its default setting or setting it on OFF
Just go to Set up Menu and look for the Date Imprint and set it to OFF.
There are other option where the Date Imprint will be disabled.
- When the Continous Mode is set to Continous or BBS
- When the Scene mode is set to Sports, Museum, or Panorama assist.
- When movies are being recorded.
Hope this information will help you and can answered your question.
This Camera doesn't have the feature to superimpose the date on the pictures. By using the supplied Picture Motion Browser Software, you can print or save the pictures with date. Refer the following link to use the supplied Picture Motion Browser Software to print or save the pictures with date.
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
When you turn on your camera, press the menu button. That will bring up the screen that has the orange buttons at the top (Capture) (Setup) arrow down using the buttons on the far right side. The down button will be the dame button that you use to delete pictures with. When you get to the botton of the page continue arrowing down and that will bring up another page. Arrow down until you get to the botton there are only 3 items on this page and the bottom item will say the following:
Date imprint ON
Press your enter button (ok button) and up will pop ON or OFF.
Arrown down to the OFF and press enter and that will remove the date imprint from your pictures.
Dear Bryx, Unfortunately there is no way to have the nikon d80 print the date directly on the images, but the information is stored to the EXIF data on every image.
It is not possible to embed the date/time stamp as part of the image itself with the XT. The date/time information is stored as part of the exif information stored in the image at the time of shooting.
However, you do have a couple options for printing images with the date/time stamped onto the image:
If you use the direct print capabilities of the camera when connected to a compatible printer (PictBridge, CP, or DirectPrint are all supported), you are able to enable an option that will print the image with the date/stamp printed on the image. There are also software packages that you can use that will do the same when printing from the computer.
And finally, it is possible, with some photo finishers, to request that they imprint the shooting date/time on the image. This will vary from photo finisher to photo finisher, and the will be some who can't, or won't, do this.
