You can click on the link below to see step by step instruction to resolve the Ink system faliure error. These messages comes due to cartridge or print head issues.
Click here >>> Ink system faliure
Regards,
Shrey
SOURCE: Ink System Failure (Error 0xc05d1381)
To resolve the issue, use the following steps.
Step one: Remove the cartridges
Make sure that the product is turned on and then disconnect the USB cable from the back of the product.
Open the product cover and remove the cartridges.
Close the cover and wait for a message to insert the cartridges to appear on the control panel display.
Disconnect the power cord from the back of the product.
Disconnect the power cord from the wall outlet and wait for one minute.
Step two: Reinstall the cartridges
Reconnect the power cord to the wall, reconnect the other end of the power cord to the product, and then turn on the product if it is not already on.
Open the product cover and reinstall the cartridges.
Close the cover and print a calibration page, if prompted.
Print a self test report to make sure that the product can print.
Reconnect the USB cable between the product and the computer.
Try to print a document from an application on the computer.
If the issue has not been resolved, contact HP to review these troubleshooting steps and evaluate if the product needs to be serviced.
SOURCE: hp c7180 ink failure
you can find the reset sequence for C7180 Ink system failure at: http://www.inkbank.com.au/webcontent21.htm
it's just a matter of pressing a few buttons on the printer...
good luck
L.C.
SOURCE: Ink System Failure Error: Oxc18a0001
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a message on my printer Ink System
Hi
Please
do this and let me know
Unplug the printer, then pressing the help
and ok buttons simultaneously plug it back in.
Let me know or Call
+877 889 6859
