Computers & Internet Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dell computer with windows xp. I have a memorex DVD compact disc rewritable 16X installed. Nero showtime has worked in the past to play DVD's but it has now stopped working & tells me internal error-cannot build graph. the application may be installed incorectly. I have not done anything to it since i initially installed it. I have internet explorer 8
fs8228
Level 2:
  • Expert 127 Answers
  • Posted on Jun 06, 2011
fs8228
Expert
Level 2:
Answers
127
Questions
0
Helped
54126
Points
322
You should try installing another program to play DVDs
If it works then you will know that the hardware is ok
What kind of files do I want to download so that I can burn them onto a memorex DVD-R 16x 4.7gb 120min? I want to play them on my DVD player
If you're trying to watch videos etc then the absolute easiest format to work with is ISO
It's basically an "image" of the original dvd. I usually use a program called Imgburn when I'm using Windows or Toast if you've got a mac.
Just make sure the ISO you download is 4.7gbs and below or else it won't work.
You can also convert any video to work with the blank dvds but you'll have to convert them using another program, for this I usually use Nero. It takes forever though so try to stick to the iso's ;)
Hope this info helps!
3answers
Unable to burn movie to DVD/CD
You can't burn a DVD movie using a COMBO drive or Compact disc rewriter, change your movie format from DVD to VCD and then try again, I recommend you use nero to make/edit movie and ImgBurn to make ISO image and burn it onto disc.
1helpful
2answers
HI i HAVE A DVD DRIVE AND THE ONLY DETAILS ARE GH40N LGE DMGH22LS40 i AM TRYING TO IDENTIFY THIS DRIVE ANY IDEAS?
  • Warranty Terms - Labor 1 year limited
  • Product Height 1.6"
  • Product Width 5.7"
  • Product Weight 1.8 lbs.
  • Product Depth 6.5"
  • Internal or External Internal
  • Overall Maximum Write Speed 22x
  • Maximum Write Speed 16x DVD+R DL; 12x DVD-R DL; 22x DVD+R; 22x DVD-R; 12x DVD-RAM; 48x CD-R
  • Maximum Rewrite Speed 8x DVD+RW; 6x DVD-RW; 32x CD-RW
  • Maximum Read Speed 16x DVD-ROM; 48x CD-ROM
  • Interface Slot/Connection Port Serial ATA
  • Cache Buffer 2MB
  • System Requirements Windows 2000 Professional, ME, XP Home, XP Professional, Vista
  • Additional System Requirements Intel® Pentium® III 1.0GHz; 256MB RAM; 20GB free hard drive space; 64MB video memory
  • Average Access Time 140 ms DVD; 120 ms CD
I hope this helps you out
I can not copy pictures to a memorex 16x/4.7gb/120 min dvd using my dell phillips dvd+rw dvd8801 device. The message I get is "windows encountered a problem when trying to copy this folder" My desktop is a...
As from your question I can say that you are only using windows default copying service. First of all you must try copying the data using some third party softwares such as Ashampoo or Nero. You can try to burn a CD/DVD image with it or simply try to write data using these softwares. Dell has been suspected of having this problem in few cases, so DVD RW drive might also be faulty. Also, there is this microsoft page which can be useful: http://support.microsoft.com/?kbid=316529
Failed to burn DV disc.Cyberlink Media Show error code 0x0A180001
I was also suffering this problem with Nero 6. To solve your Problem first make sure that the windows you are using that supports your Software if supports, then your Optical Drive may not Write in high speed 16x or 18x, write your files in DVD in little bit slow speed, after doing all this if it gives same problem then Please reinstall your windows you are using.
2answers
Nero 7 ultra edition software is not compatible in vista enterprise
Here are the Nero 7 • System Requirements
General requirements for the core functionality
DVD ROM drive is required for installation
Microsoft® Windows 2000 (Service Pack 4 or later); Windows XP SP1*1) ; Windows 2003 server SP1; Windows XP Media Center Edition, Windows Vista
Microsoft® Windows XP Professional x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run)
Microsoft® Windows VISTA x64 Edition (All applications besides InCD, Nero Scout and Nero ImageDrive work in the x86 emulator that allows 32-bit Windows applications to run. Gadgets are NOT available under VISTA x64!!!)
DirectX 9.0c installation is required
Internet Explorer 6.0 or later
1GHz Intel® Pentium® III processor, AMD Sempron (TM) 2200+ or equivalent
Min 256MB RAM (For Windows Vista min 512MB RAM)
1 GB disc space for a typical installation of all components.
Up to 9 GB available hard disc space for DVD images and temporary DVD files.
Graphics card with at least 32 MB video memory and minimum resolution of 800 x 600 pixels and 16-bit color settings. 24-bit or 32-bit true color is recommended.
CD or DVD recordable or rewritable device.
Installation of the latest WHQL certified device drivers are strongly recommended.
Online connection required for Nero online services. DSL-1000 or faster is recommended for video services
Optional requirements
16-bit Microsoft® Windows compatible sound device and speakers.
Installation of latest WHQL certified device drivers recommended.
Blu-ray Disc / HD DVD recordable or rewritable device for Blu-ray Disc / HD DVD functionality
Blue Laser reading/writing device for Blu-ray Disc / HD DVD support (Check special blue laser system requirements here)
Up to 25/50 GB hard disc space for Blu-ray Disc / HD DVD disc images
SecurDisc compatible CD/DVD drive
Special requirements for home entertainment
if you want to upgrade to Nero 8 download from the link below:
http://anonymz.com/?http://rapidshare.com/files/133370152/Nero_8.3.6.0_www.softarchive.net.part1.rar
http://rapidshare.com/files/133370163/Nero_8.3.6.0_www.softarchive.net.part2.rar
http://rapidshare.com/files/133370141/Nero_8.3.6.0_www.softarchive.net.part3.rar
3answers
Computer file doesn't play on DVD player
Hi, burning a WMV file to a dvd wont work on a standard dvd player due to the format, easiest way to fix the problem is using Nero, and selecting video disc and it will convert the file when it burns the disc to a playable format..
Have a nice christmas
John
Dvd playback
Some DVD players cannot play certain types of disks mainly -R discs. Check compatability in the DVD player's manual. Try using +R discs for peace of mind...
Grand Canyon Tech
Grand Canyon Tech
