Posted on Aug 18, 2008
Sony hcd-va550. when switched to cd the display reads initial.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
605
Points
No display ,no sounds standby only
no display ,no sounds standby only
my sony hcd-gn1200 no display stanby led only
Sony HCD FLX5D not turning on
I know Ashish you fixed it but which transistor was it? Can you please let me know as i have the exact same problem....
I too have a Sony HCD-NE3. Some cd's will play
It may be that the pick-up has micro dust on the lens. These plastic lenses will attract this small dust. you can clean it off with a bit of windex on a very clean swab. If it does not work then the spindle table height may have slipped down and the lens is outside it's focus range.
2helpful
I have a Sony CD/tape player model # HCD-NE3. When trying to read a CD - it says NO DISC. What should I do?
Typically a no disc display indicated dust on the optical unit ( lens ) or failure due to low laser beam emission. For the first case you have to remove the top cover and clean the lens very gently with a ear bud. The the cleaning does not solve your problem you have to replace the optical unit itself. Unless you have experience doing the above i won't recommend it. Replacement will cost you about 15$ plus labor.
3helpful
I have Sony HCD-RG290. It is telling mechanical error when i want to change cd or listen cd or open the cd-box. It gave once that error and i went to repair with it and the man said that it is really small...
I have a SONY compact disk deck receiver
model no / HCD-RG290.
Whenever i switch it on it comes on then automacticaly switches itself back to standby mode & dont know why, can you help?
my e-mail is [email protected]
I have a Sony Compact Disc Receiver, Model HCD-VA550. The audio cassettes and tuner work. The CD flashes "Initial", and the CD door won't open and our new CDs (5) are stuck in there. I note a few others...
I have the same problem and have worked past it by turning the unit off, waiting until I hear the mechanism stop completely and turning it back on. Sometimes this works the first time and, more often, I have to repeat the process several times. Eventually everything comes up as it should and the unit functions as it was designed. It doesn't work long, and almost always has to be 'rebooted' the next time I want to use it. Except that it is a great unit when it works, I would toss it on the garbage pile and get something else.
2answers
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
5helpful
2answers
Sony cd deck receiver HCD VA550
I have the same issue. Did you get an answer ?
Sony system shows "initialising"
probably your laser is weak,if you're not qualified to open pls, visit nearest sony service center to have the laser replaced.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
