Bad motor or you need to remove the shipping bracket that immobilizes the motor during shipping.
Call the Fan manufacturer if your past the 30 day department return window, but still within the one year manufacturer warranty. If you paid by credit card-they extend the warranty an extra year for you. Also, check your wiring to make sure you connected black/blue wires together to the black wire coming from the ceiling and the white wire to the white wire coming from you ceiling.
Go out and spend the money for a Hunter Fan. They have good ratings and customer satisfaction.
SOURCE: fan making humming noise and wont turn
The fan motor cannot turn because either the bearings are dry and turning hard or the motor has worn out...You can try to take it apart and lub the bearing with WD-40 and a light oil... it may work.
heatman101
