Heating & Cooling Logo
Anonymous Posted on Aug 18, 2008
Emptying Water My PAC210U portable is spilling water when I try to move it...how do I empty the tank?  How do I get at the tank?  I do not have a manual.  This is a 5 year-old (approximate) 29"Hx22"Wx14"D.     Jim I need an owners manual/operating manual for the PAC-L90. Where can i get one?
Anonymous
Level 3:
  • Master 1,420 Answers
  • Posted on Aug 19, 2008
Anonymous
Master
Level 3:
Answers
1420
Questions
Helped
849204
Points
3861
Anonymous
Level 1:
  • Contributor 1 Answer
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1844
Points
I printed the users manual from the computer.
thanks.
1 Related Answer
A
Anonymous
  • Posted on Aug 26, 2008
SOURCE: Emptying Water
open the big front door, pull the top of the water container toward you, take it out turn it over, unscrew the top, pour out the water
1helpful
2answers
DO I NEED TO DRAIN THE WATER IN REGULAR USE?
The Everstar Model# MPN111CRBB4 is a portable air conditioner. Based on the information available, it does not require a constant drain to be hooked up. Instead, it is designed to collect the condensate water generated during operation in an internal reservoir or tank.
Typically, portable air conditioners like the Everstar MPN111CRBB4 have an automatic condensate removal system that uses the collected water to enhance cooling efficiency. When the internal tank reaches its capacity, a "full tank" indicator will usually illuminate on the control panel, indicating that it needs to be emptied manually.
To empty the water tank, you can follow these general steps:
  1. Turn off the air conditioner and unplug it from the power source for safety.
  2. Locate the water tank or reservoir on the unit. It is often located on the back or bottom of the air conditioner.
  3. Gently remove the tank from the unit. Be cautious as the water inside may spill if the unit has been operating recently.
  4. Empty the water from the tank into a suitable container or drain.
  5. Once the tank is emptied, carefully reinsert it back into the air conditioner, ensuring it is securely in place.
  6. Plug in the air conditioner and resume normal operation.
Regarding the ports on the unit, the top port you mentioned may be used for attaching an exhaust hose to vent warm air out of the room. However, it is not typically used for drainage purposes.
1helpful
After flushing the toilet and later the water in the bowl became dark yellow and badly smell
you have back fill in the plumbing pipe it will need to be investigated, you may have a blocked pipe or your spill tank is full and needs emptying.
Jul 07, 2017 • Home
2answers
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Emptying Water
1helpful
4answers
Water empty light wont go out
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
