SOURCE: feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
SOURCE: plastic panel came loose under car, near where front area close to underneath radiator?
just a guard to stop stones an general rubbish sticking to the bottom of the rad hope this helps
SOURCE: F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
SOURCE: ran off road and bottom plastic panel under the
Yeah, you can do that or you can go to an auto supply store and get new fasterners and re-install. That piece is basically like a skid plate it is to protect the undercarriage from the rocks and other road debris from popping up and damaging engine/vehicle components.
