SOURCE: no ring,goes directly to voicemail
your phone is on 'do not disturb mode'. call your provider and ask how to shut it off. for telus mobility it is *79 then hit send
SOURCE: How do I change the number of rings before my voicemail answers?
You need to contact your service provider to have them extend the ringtime. This can be done, up to 30 seconds.
SOURCE: Block one number from calling and texting me
Hi
some Samsungs have a 'block list'. I am quite sure that the D900 has it. All you have to do is when you receive a text from this number select options, and you should see in sub menu 'add to block list'. I am not sure if it also blocks calls once added to the list? Hope that helps?
SOURCE: I have a Omnia i900
Strange problems with omnia regarding boot may caused ..
There is a JTAG solution for competely dead phones
Those help you to read and write boot ! where you can not do with standart tools and cables .
you can find on the net
www.omnia-repair.com
Ps : if you think it is not neccessarry to buy
i can suggest to contact and ask for help to repair your phone .
Best Regards
