SOURCE: do i need to update
No need. You just have to make sure that your 2 network adapters are installed correctly like the one for LAN and the integrated wireless adapter.
SOURCE: driver for microsoft virtual wifi miniport adapter
Here is the download link for Microsoft Virtual WIFI MiniPort Adapter
ftp://ftp.research.microsoft.com/downloads/994abd5f-53d1-4dba-a9d8-8ba1dcccead7/MSRMesh-VirtualWIFI.MSI
I'm giving you the link as you want to download the driver, but still your WiFi will work without Microsoft Virtual WIFI MiniPort Adapter driver.
It's just a New Technology wihich comes with Windows 7. It's function is two connect more than one Wi-Fi or hot Spot connection at the same time.
Rate this solution.
SOURCE: HOW TO N WHERE TO
go to the drivers and downloads page at microsoft.com...if not there then try the manufacturer of the pc
SOURCE: microsoft virtual wifi miniport adapter
Hi
take a look here you may find what you are looking for please click on drop down boxes to select your make and mode then os
http://support.gateway.com/us/en/emac/product/default.aspx?tab=2
then scroll down or type in search box what you are looking for
good luck
also you could look for a scanner some websites use a scanner to scan your laptop to offer you some drivers or updates but you will have to go up top of your screen and allow the scanner to load if you want to use it. it is good practise to use the scanner when its available
good luck
SOURCE: the driver installed for microsoft
Hi
if you go to computer properties
then device manager
find the miniport adapter
un install it
then restart laptop
hopefully windows will reload it on startup
and maybe then it will be ok
if not go to the website of your laptop and download another driver for it
type into your search engine the make of your laptop then search for your model and os
then search for the driver here are a few examples on how to type in your manufacturers web page
www.acer.com www.hp.com www.compaq.com
