SOURCE: Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
SOURCE: 64802 Top Freezer Refrigerator: dripping water back of refrigerator...
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
SOURCE: Freezer door started dripping water when opened
Hi and welcome to FixYa. I am Kelly.
In the fresh food compartment center overhead within about 6 inches of the front of the unit there is a circular hole. Inside that hole you will see a dial with 2 tabs on it. Use your thumb or a squared off utensil and rotate the tabbed dial slowly until you hear an audible "CLICK" The refrigerator should stop running and the defrost cycle begins.
After 45 minutes (+ or - 10 mins) the compressor should start again. Once the compressor starts, check both the evaporator fan in the freezer compartment and the condenser fan in the bottom rear of the unit to make sure they are turning at full speed.
If the compressor does NOT after 90 minutes re-start, rotate the defrost timer tabs of the dial in the overhead of the fresh food compartment until you hear it start again. The fact that the compressor did not start in under 90 minutes indicates a defrost circuit problem.
A slow running evaporator fan or condenser fan will cause poor cooling. Also in the back of the unit, check the right side of the condenser coils for lint / hair build up. If it is blocked the front outside chassis of the freezer section will be very warm almost hot to the touch. Clean as needed with a vacuum if you do find any lint buildup.
Once more thing is to check the ice maker. Quickly touch the bottom of the ice maker. If it is VERY hot to the touch then there is a problem with the ice maker itself and the mold heater can cause your freezer to warm up and overall unit performance to degrade.
A complete checkout of the ice maker can be found here: http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48360
Scrolling the left side of the page will access all sections of the unit.
Thanks for using FixYa.
Kelly
It sounds as if you have an automatic defrost problem.
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
