Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Router cannot be detected - D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
    New Friend:
  • 159 Answers
Try doing a factory reset on the router.
Hold down the reset button for 20 seconds and let it go through its reset.
Please rate my solution to show your appreciation!
For more tips visit my blog at http://thegeektweet.wordpress.com
Posted on Jun 04, 2011
6ya staff
SOURCE:
My compaq presario v2000 laptop cannot detect the wifi signal of Zyxel router. It can detect all other router brands. I'm sure that my Zyxel router is sending signal because I can detect it using my...
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
Sep 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Can't access my linksys on my laptops although I can on my desktop.
Hi ottawakids,
I see that you are having issues accessing your Linksys using your Laptops.
> First Check if the router is detected on the Laptops.
>If the Router is detected and un accessible you ill need to check if there are security settings in the Linksys Router.
>Check if the Linksys has a Network key, or check if the Router MAC address Filtering is turned ON the Router this can also prevent your laptops from accessing the Router.
>If all elsa fails try resetting the Router to defaults and start from scratch maybe some settings are incorrect, setting it to default will fix the issue of the Router not being detected.
I hope this helps.
Have a nice day.
mvincentc
Oct 20, 2010 | Linksys Wireless-G Broadband Router
I'm setting up a new router. I was instructed to go to routerlogin to work withy settings, but I am directed to a web page, not the router. How do I complete setup of the router?
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
7. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
8. Click Apply.
9. Logout of the router.
10. Open up another browser window and try to access internet.
regards,
prakash
Mar 16, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Laptop (Vista) detects zyxel 320w router but won't connect
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 16, 2010 | Zyxel P320W 802.11G Wireless Firewall...
Router not detected by wii, ps3, laptop
may be the wifi is switched off under the router or its in hidden mode, updrade the firmware of the router and then re configure it ... problem fixed for sure
best of luck
Jan 11, 2010 | Linksys Wireless-G WRT54GS Router...
Attached router for x-box connection not detected. turned off router, turned back on, reconnected physically the new x-box receiver--no connection detected--help
Dec 31, 2009 | Microsoft Xbox Console
Router dell 2350 not detect by computer
open a explorer session go to tools/ internet options/connections/lan settings check off Automatically detect settings click ok, ok close explorer then open a new session and see if you get internet.
Oct 17, 2009 | Dell Wireless 2350 Router
Belkin g+ mimo router can't detect internet
have you tried resetting the network adaptor on the belkin, whictch provider are you using for internet connection?
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection problem
Hello There, are there any wireless computers that detects your router? If there is, most of the laptop computers has a built-in on/off (toggle) switch on the side to enable or disable the wireless card on your computer. Make sure it is "ON" then check if it will detect the wireless connection.
If it is a desktop, try to reboot the computer then check again. If none of the computers can detect your router, make sure that the wireless light on the router is lit up. You may also try changing the channel on the router.
Aug 03, 2008 | Airlink Computers & Internet
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
