it runs with a setting less then what the unit says the current humidity level is and never collects water. Shouldn't the coils get warm when freon is flowing through them properly?it runs with a setting less then what the unit says the current humidity level is and never collects water. Shouldn't the coils get warm when freon is flowing through them properly?
You can't post conmments that contain an email address.
the unit does not require 'recharging' unless you've had a refrigerant leak - in which case you will need a qualified AC TECH to recharge it for you, after, he/she has found and repaired the leak.
But, as I said above, without a leak in the system you do not need to recharge it.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
There can be many reasons why a dehumidifier will
not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong
with their dehumidifier
call 1-866-629-8241. they are no longer honoring the warranty because the company that made the dehumidifier (fedders) went bankrupt. they will prorate the warranty and send you a check. we had two months to go on ours and they sent us a check for $14 and change.
