My cellphone is off I've tried unsuccessfully to get the phone turned
on so I can use my At&t sim card in I've tried the four 0000's to get
the phone something blocking it over in the right hand corner at the
top by the battery and the key sign next to it is a X .The phone is off
everything else works perfect, please help I want to use this phone
thank you
The D807 doesn't have the option to copy all contacts to the SIM from the phone by using key presses on the phone, only to the phone from the SIM. Best solution, if you still have the CD and USB cable that came with the phone, is to use the software option. The management software allows you to manually move all those contacts to the SIM, or to your computer, which is a better idea because the SIM doesn't store the data in the same way so some is lost. For example, the phone stores a name as two separate parts, first and last, but the SIM only has a single data entry for the name so you lose the last name from each of your contacts if you directly pass the data to the SIM.
The same happened to me. What you do is, your supposed to enter the code. If it doesn't work, enter your password from before. Everything is erased because it reset itself. There is nothing yoou can do. You can also bring it to a Verizon Store for them to restore your contacts and music.
Most likely it won't help.
one reason might be is that , your phone might be network locked and hence it is rejecting other SIM, If that is the case try unlocking your phone to use other networks, http://www.theunlockarena.com/ will help you with the process
Let me give you a little background and then some solutions. This is generic because I don't know your carrier. I've used ATT as an example.
Phones are naturally unlocked, but a service provider might lock them
When originally manufactured, all GSM cell phones are unlocked. That is, they can be used with any SIM from any cellphone service provider - always assuming, of course, that the cellphone service provider has compatible GSM service on the same frequency bands that the phone can operate on.
Most cell phone service providers electronically 'lock' the phone so that it can only be used with their service. There are obvious reasons why they choose to do this - in particular, to force you to pay what are usually very high roaming charges when you take your phone out of their network and use it elsewhere in the world.
Fortunately, this locking is reversible. With some phones, it is possible to simply enter an unlocking password code into the phone and it is immediately then unlocked. Other phones need to be connected up to a special unlocking data terminal.
Your phone has to be unlocked by the carrier. LG, Motorala, Sony Ericsson, Nokia and most of their ilk, will not give consumers the unlock codes but don't despair.
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from your carrier. For example, if you have AT&T to unlock your SIM card, you can obtain your phone's PUK code from AT&T by:
● logging in to your myWireless Account online ● using their Technical Support Chat ● calling Customer Care at 1-800-331-0500
To get your phone's PUK code online from ATT:
● Log in to your myWireless Account. ● Select My Services under My Account. ● From the My Services screen, select My Phone/Device. ● Select Unblock SIM Card. ● The Unblock SIM screen will display your PUK code.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong ATT PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
There are three other ways to unlock a phone:
● The carrier will unlock the phone for you at one of its retail outlets; ● You can do it yourself by clicking on this link Free Unlock Codes , ● Pay $3.89 at the following website: www.theunlockshack.com/.
I trust that this is helpful and solves your problem. All the best
operate on.
● Pay $3.89 at the following website: www.theunlockshack.com/ .
Phone lock code is totally different from a PIN or a PUK.
The default Phone lock code for most of the sony Ericsson is "0000" (Four Zeroes)
If you are looking for a phone lock you can try putting the above code. If you have mistyped the PIN and then the PUK then the SIM card itself is corrupted and in that case you will have to replace the card.
I have to inform you that China sells alot of "unlocked" phones some of
them are legit some are not.There are alot of conterfeit phones coming
out of China you have to be careful. It's clear that the sim card is
fine if you used it previously in another AT&T phone.
The problem is the phone itself, either A. it is not unlocked as it was
advertised to be or B. the phone is bunk period....can you post the
website you purchased this from ?
There is not much we can do from this site, AT&T was your best bet.
Typically they will not deal with "unlocked" phones did you mention to
them that you purchased it from China ?
Post back with the link to the site or any other questions you have for further assistance. Thank you for choosing Fixya!
