Sirius ST4TK1MSA Satellite Radio Receiver with Car Kit Logo
Posted on Jun 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After one year I wanted to install it again, but a message :no antenna detected , appear in the screen, all cables are attached correctly. thank for your help
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Jun 03, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
32129
Points
233
You can try to power cycle the receiver and try to unplug the antenna and plug it back in. Another option is to check the cord for any frays or cuts.
I have a sanyo1080p. Upon disconnecting the
Has the cable come away from the antennae plug?
is the lead still attached to the aerial?
What message is displayed on the screen?
Len..
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
Why does it say no signal with a blue screen
Assumtions, but you should check:
Make sure the cable/antenna is attached properly
If you have a cable service, make sure it's active.
On initial power up, use the menu to navigate to the input selection screen, and choose the correct option for your application. Also worth noting is that there is a second menu page where you select cable or antenna. Check that too.
Please post your findings.
Thanks.
Joe
1helpful
Channel setup
You will have to run the Autoprogram menu function from the menu. Here are the steps
Press the MENU button on the remote control.
Use the cursor down to select Installation in the Settings menu.
Use the cursor right to enter the Installation menu.
Select Autoprogram in the Installation menu.
Use the cursor right to enter the Autoprogram menu.
Press the OK button.
Select Cable or Antenna in the Installation mode.
When Antenna is selected, the TV will detect antenna signals and will search for antenna TV (NTSC and ATSC) channels available in your local area.
When Cable is selected, the TV will detect cable company supplied signals and will search for cable TV (NTSC,ATSC, QAM modulated) channels available in your area.
Make sure that registration with your cable TV provider and connection of equipment are completed.
Press the green button “Next” on the remote control.
Press the green button “Start” to start autoprogramming.
The menu screen disappears and the progress of autoprogramming is displayed.The progress bar indicates the number of analog and digital TV channels found. (Also digital channels via CableCARD are being programmed.
When Autoprogramming is complete, a message appears confirming the completion and the TV switches to the first installed TV channel.
2answers
Kingston Flash drive is NOT accessible (8GB)
my flash drive is not supporting my computer kingston
2answers
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
No HP devices detected. HP Solutions Center will close now.
Unistall the software you have for it now. Go to HP.com and look for Vista drivers for your printer.
2answers
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
3answers
My GPS cannot locate my own position
Try GPS data reset. At user screen push the zoom out key and repeat button at the same time. Select Reset GPS data. This will reset the GPS settings. If after this you are still not getting any signal then you may have a loose RF cable inside your unit. If you feel comfortable opening up your unit and making sure the grey or black cable going from the big (main board) board to the board attached to the rear housing, then do that. Of course this is at your own risk. If you still get nothing after that, it may have something to do with your antenna, which you'll need to take off prior to opening your unit. Turn the antenna all the way out (past perpindicular to the unit) and pull straight out. make sure the connector isn't bent. Keep me updated if anything changes. _Daniel
2helpful
5answers
Camera is not working
This sometimes happens with the cd driver, uninstall your driver first, the try loading this driver http://www.logitech.com/index.cfm/downloads/software/US/EN,CRID=1794,contentid=11022. Just check that when Windows says device is detected, see if it actually states your camera make and model, then says, your hardware is installed and ready to use, and NOT your hardware is installed but may not work correctly. If you still have problems, see this page, as there are a few workarounds. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=534&p_created=1087233145&p_sid=tDSxcPki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQyMiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aWxsIG5vdCBpbnN0YWxs&p_li=&p_topview=1
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
