Question about Peavey PR15 400w PA Speakers
What is the fuse name/type - Peavey PR15 400w PA Speakers
    New Friend:
  • 59 Answers
Those are Red Dot Lamps. people most comonly know them as red dot fuses, ( whatever ) it just goes on the crossover to protect your hfd. if it blew you might want to take time to check your Tweeter.
Posted on Sep 27, 2011
  • Keith O'Bryan
    Keith O'Bryan Sep 27, 2011
    There are Red Dot , blue Dot, and No dot. You deffently want red. Just to be more clear.
What type of guitar is it other than accoustic need more details
There are two main types of acoustic guitar namely steel-string acoustic guitars and classical guitars. Steel-string acoustic guitars produce a metallic sound that is a distinctive component of a wide range of popular genres.
May 10, 2015 | Music
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 | Music
Need a fuse cover/door for a Kurzweil k2661. How can I allow continuity? It is not your typical fuse. It appears as though the fuse door must have prongs that plug into the power supply via the rear.
You will ikely have to purchase the whole power entry module, but use only the boat that holds the fuse. Find matching part at DigiKey.com.
Example: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=Q205-ND
Search for "power entry" to get a list... many do NOT have fuse and many do have and you can use the photos to match what you need.
Jun 01, 2011 | Kurzweil PC361 Performance Controller
The fuse holder and fuse fell out while in upright position. I borrowed the amp from a friend. Where can I find the cap that holds the fuse in, and what fuse do I replace it with?villaslasolas
You are in big trouble! You will wait months to get the part from Behringer. Here is link to similar itrem from Digikey.com. Search for keyword "fused entry"
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=708-1332-ND
This may or may not be the exact match and they have several similar types. You will have to buy the whole power entry unit as finding the exact "fuse drawer" is not likely.
I believe you shoukd use a 6.3 amp fuse in the unit and the size to fit the fuse drawer in the entry unit,
Feb 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
So, i think I've blown the fuse in my Marshall MG 100 HDFX head (I tried to run 2 speaker cables out of the head into a quad...stupid >.<). What type of fuse do these heads use? How can i access...
The fuse is inside the unit so as to force you to open it and look for damage.
The fuse is likely a 3 amp/250 volt type.
Replace the fuse and then put a 100 Watt light bulb in series with the hot side of the power input. If the lamp stays lit with no load on the unit, then there is damage that requires repair before use. If you just replace the fuse repeatedly you may damage further components.
In the future obey the minimum resistance load on your amps.
Aug 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Why does it say "Illegal song name?" No matter what I type in for a song name on my Fostex MR-8 HD I get this same message. I am not typing in the name of a song already recorded. Even if I just use the...
Note that the name of the song CANNOT have blanks and the use of special characters is limited.
If you need a space in the name you have to use the underscore to creat a "space".
Mar 20, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
What type of fuse would you use for Mackie tweeter?
I would contact Mackie and see what they say. The MR5 is already protected internally by the built in amplifier circuitry as far as I know.They can be reached here:http://www.mackie.com/support/index.html
Oct 28, 2009 | Mackie MR5 MR5 Reference Monitor
What kind of fuse does a Peavey PR12N sound reenforcement(PA) speaker take? Blew the internal fuse and cany find one(locally) Looks very similar to a cars interior ''dome'' light bulb
According to the Peaver PR12N Manual which can be viewed at http://www.peavey.com/assets/literature/manuals/pr12p.pdf
This unit requires a ABC Type Fast Blow 5 Amp fuse. The replacement fuse must be of the correct type to properly protect the unit. If the fuse continues to blow repeatedly the unit should be taken to a qualified service center for proper repair.
Aug 22, 2009 | Music
Peavey PR15 400w PA Speakers Logo
242 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
PNiss
Are you a Peavey Music Expert? Answer questions, earn points and help others
