This often has to do with a network error, or your phone its self. The best solutions are as follows.
If the above solutions do not work you might need to consult with your wireless provider.
When attempting to view the message, pressing the menu key after receiving the error will often times allow you to attempt to redownload the message.
Step 1) Open MMS Message. If you get the error code again, go to step 2.
Step 2) On the error code or highlighted message, press the menu key.
Step 3) Highlight an option that says "Retrieve" or "Download" message, when you have sufficient mobile coverage.
Step 4) If you receive the message again, check to see if your data plan allows for MMS messaging.
You should check MMS profile setting. The proper setting should be configured before sending or receiving MMS. To retrieve the MMS automatically, you should set the settings at "Auto download" settings. To check,
1. Go to Message from the idle screen.
2. Go to "Settings" and then "Multimedia messages."
3. Select "Receiving options" and "Home network."
4. Go to "Foreign network" menu and check the status
5. If it is set at "Auto download", you can receive MMS automatically.
6. If it is set at "Manual", you should operate MMS retrieve function manually.
