The bezel from my Invicta Pro diver 8926 came off, and I dint know it had a gasket in it. I lost the Gasket, so now the whole bezel is loose. Where can I find a replacement gasket?
invictawatch.com/collections/view-model/15342-pro-diver INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
unscrew the crown first means turn the crown anticlockwise then pull out to adjust the time.go to the link below for instructions
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
mcdevito75 here, Use the waranty info from the box and call Invicta. In the meantime, turn the winer stem and hold the watch close to your ear do you hear a clicking?? Some automatic watches will only wind while they are in motion on your wrist, Hold the watch in your hand a turn your hand in circles and see if the watch starts up.
The answer to your specific question is the 2nd instruction below...I've also included two other settings: Here are the 3 main crown positions
you need to know once you unscrew it from its locked down
position:
1) unscrewed, it can be manually wound, in one direction
[clockwise}...20 to 30 half-turns seems to be good to get it through
the night.
2) then, pulled out one small stop, the date can be advanced by turning the crown towards you (ie, counterclockwise) 3) pulled out one more stop, the time is adjusted by turning the crown. I hope this helps!
I know of a couple places in San Antonio and Austin that would be able to custom fit your new band or help you with a repair.
Precision Time
They are located in the malls in either city. They also have a web site.
PrecisionTimeCo.com
You can try to contact Invicta for new links and they may have them depending on the age of the model. Look at your owners manual for contact information.
