Unless it can be 100% gravity feed (1 inch drop per foot) you might need this: Description: Pump-drain No. in Pack: 1 Additional info: Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window. Price: $107.79 -
Part: WPL8212501
Fits Maytag M7DH45B2A
(Click images to Enlarge)
Stock Status:
In Stock
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
