The readout shows Relative Humidity in percentage % where 100% would be soaking wet and 20% would be dry. The weather station on my desk show my room is 32% and DRY. You need to lower the number from 58/60% to make it remove moisture.
Hey Darwin,,,, By dehumidifier.. Do you mean air conditioner.. if so, the issue is more than likely you are low on freon.. have it charged and you should be fine.. If this does not fix the problem, it could be the compressor, the pressure switch or the fuse..
Hi There, I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
